#1 Posted : Sunday, June 29, 2014 7:09:46 AM(UTC)
Please help as I am confused.
Although I found a nice basic UV map that can be resized and/or transformed to be used in a virtual studio I don't manage to create one myself
as I understand it is made up of a red and green layer (gradient) and adding (mode) them together I do visually get the exact same visually as the one I found online that works.
BUT... that one always give a distorted view (vertical lines , horizontally half the size approx basically a total mess
what is the trick please
I did notice that some virtual sets that use UV maps seems to use a different standard one compared to the one used in vMix.
Inquiring minds like to know
#2 Posted : Sunday, June 29, 2014 8:06:01 AM(UTC)
Was thanked: 4742 time(s) in 1628 post(s)
See below:
http://www.vmix.com.au/k...ual-set-specification-10
UV Map PNG files need to be 64bit so the red/green colours can range from 0 to 65535
thanks 4 users thanked admin for this useful post.
doggy on 6/29/2014(UTC), Thremir on 6/29/2014(UTC), claudeir on 11/30/2018(UTC), smudge1977 on 4/30/2020(UTC)
#3 Posted : Sunday, June 29, 2014 9:35:34 AM(UTC)
ok, that works , but my edges (when video is panning are distorded )
Imagine this i where the gamma corrected comes into play , any hints please
#4 Posted : Sunday, June 29, 2014 9:47:52 AM(UTC)
If you can provide a screenshot it will make it easier to see what might be happening.
#5 Posted : Sunday, June 29, 2014 10:10:31 AM(UTC)
sending clip by email as it becomes most obvious (panning)
#6 Posted : Sunday, June 29, 2014 10:16:19 PM(UTC)
There appears to be a problem with your gradients.
They start out 0,1,2,3 etc as they should but then go back to 0 again towards the start.
They need to evenly increment across the entire image for it to look correct.
#7 Posted : Monday, June 30, 2014 12:39:00 PM(UTC)
Thanks Martin and I understand ... just dont seem to manage it or maybe gradients aren't correct on PS ;-)
#8 Posted : Friday, July 4, 2014 4:21:31 AM(UTC)
Here is a sample set with a HD 64bit UV Map:
http://www.vmix.com.au/download/uvmapsample.zip
You can try importing the image into photoshop, moving it around and saving it out
again to see if photoshop preserves it correctly.
#9 Posted : Friday, July 4, 2014 4:36:26 AM(UTC)
Thank you Martin
My problem is not being able to alter a UV map (as I found one online also and see my GoPro lens correction altering I did in this Post
repositioning , changing its shape and what not all works when starting from an example like yours and than saving it
I was trying to make one from scratch . Got close , just the edges ;-)
Tried some free to test virtual sets , just had to replace their uv map with 'ours' and 'translate' the PSD file to the vMix xml :-)
claudeir
#10 Posted : Friday, November 30, 2018 1:09:54 PM(UTC)
claudeir
Hi friends, thanks so much for your uvmap sample, Im studying that.
Please, could you send some tutorial to teach me how to create a new one with
all size that I can ?
Thanks so much !!!
LMTunkara
#11 Posted : Tuesday, March 2, 2021 11:48:07 PM(UTC)
LMTunkara
Gambia
Hi there Martin,
Did not want to create a new thread so piggybacking this one.
Thanks for the UV sample but I have this strange issue that after I resize it for my screens, when I drop videos into the inputs in vMIX, the images are heavily pixelatted? Any ideas why this happens? I have tried the sample sets that cam with the software but the videos work fine in them.
Cheers
Mark
#12 Posted : Wednesday, March 3, 2021 1:06:31 AM(UTC)
Should have, it's 7 years old !
more recent: https://forums.vmix.com/posts/m87962-UVmap-from-scratch#post87962 shouldhelp understand why just edit and saving didn't work out
LMTunkara on 3/3/2021(UTC)
Vince Beck
#13 Posted : Wednesday, March 3, 2021 2:41:57 AM(UTC)
Vince Beck
If you see a pixelated image, make sure you save as png (File>Save as> PNG) in Photoshop, don't use save for the web. And double check that you are working in a 16bit/channel mode (Image>Mode>16 bits).
thanks 1 user thanked Vince Beck for this useful post.
LMTunkara
#14 Posted : Thursday, March 4, 2021 8:45:06 PM(UTC)
LMTunkara
Gambia
Thanks for the assistance guys.
I followed that tutorial and made a 16bit UV gradient in GIMP but for some (frustrating) reason, any video I load into my screens are pixellated when I zoom in!
The background image I'm using is 4K so I wonder if that has anything to do with it? I think my config is fine (below)
I'm obviously doing something wrong but can't quite work it out.
Cheers
Virtual Set
<virtualSet>
<input name="Background" x="0" y="0" zoomX="1" zoomY="1" rotateX="0" rotateY="0" rotateZ="0" dynamic="True">background.png</input>
<input name="Main Screen" x="0" y="0" zoomX="1" zoomY="1" rotateX="0" rotateY="0" rotateZ="0" dynamic="True" uvmap="screen_main.png">blank.png</input>
<input name="Screen Right" x="0" y="0" zoomX="1" zoomY="1" rotateX="0" rotateY="0" rotateZ="0" dynamic="True" uvmap="screen_right.png">blank.png</input>
<zoom name="Full" x="0" y="0" zoomX="1" zoomY="1" rotateX="0" rotateY="0" rotateZ="0" />
<zoom name="Custom" x="0" y="0" zoomX="1" zoomY="1" rotateX="0" rotateY="0" rotateZ="0" />
</virtualSet>
Revocayne
#15 Posted : Thursday, August 19, 2021 6:25:11 PM(UTC)
Revocayne
Malaysia
You have to double check on your UVmap file if it's at 64 bit in total. You have to save your PNG in 16bits/channel which is 64bit in total.
Guest (10)
