Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Does HTTP API Call worked on vMix HD License? I read in the User Guide, it is only Script that available on vMix 4K and Pro.
Thanks a lot.
I think you're confusing All versions support using the API locally or from a remote computer. So commands like this (or from a 3rd party app) will work for all versions Code:http://127.0.0.1:8088/api/?Function=Fade&Duration=1000
Scripting is a different thing and is limited to 4K and Pro versions yes.
 2 users thanked DWAM for this useful post.
