gpdipalmerahtimur
#1 Posted : Thursday, July 16, 2020 1:10:46 PM(UTC)
gpdipalmerahtimur
Indonesia
Does HTTP API Call worked on vMix HD License? I read in the User Guide, it is only Script that available on vMix 4K and Pro.
Thanks a lot.
#2 Posted : Thursday, July 16, 2020 5:39:16 PM(UTC)
I think you're confusing
All versions support using the API locally or from a remote computer.
So commands like this (or from a 3rd party app) will work for all versions
Code:
http://127.0.0.1:8088/api/?Function=Fade&Duration=1000
Scripting is a different thing and is limited to 4K and Pro versions yes.
thanks 2 users thanked DWAM for this useful post.
gpdipalmerahtimur on 7/16/2020(UTC), doggy on 7/16/2020(UTC)
