Advice on how to link capture driver to capture modules
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
Please advice ...
The Set-up ================
We have a system ( laptop ) using sometimes 3 and sometimes 4 capture cards ( BM Intensity Pro )
The Problem ================ The vMix ( or probably Windows ) change the capture modules allocation based on the number of capture cards used.
If we have 4 cards,
Card 1 - Capture module 1 Card 2 - Capture module 2 Card 3 - Capture module 3 Card 4 - Capture module 4
If we remove a card.
Card 1 - Capture module 1 Card 2 - Capture module 2 Card 3 - Capture module 4
Capture module 3 - Offline.
We need to find a way to link the modules with the Intensity cards so the Card no 3 to be always linked to Capture Module no 3 no matter how many capture cards do we have.
Any advice ?
Thank you,
