ClementN
#1 Posted : Saturday, June 21, 2014 10:10:18 AM(UTC)
ClementN
Romania
Please advice ...
The Set-up
We have a system ( laptop ) using sometimes 3 and sometimes 4 capture cards ( BM Intensity Pro )
The Problem
The vMix ( or probably Windows ) change the capture modules allocation based on the number of capture cards used.
If we have 4 cards,
Card 1 - Capture module 1
Card 2 - Capture module 2
Card 3 - Capture module 3
Card 4 - Capture module 4
If we remove a card.
Card 3 - Capture module 4
Capture module 3 - Offline.
We need to find a way to link the modules with the Intensity cards so the Card no 3 to be always linked to Capture Module no 3 no matter how many capture cards do we have.
Any advice ?
Thank you,
