ATEM TeleVision Studio to vMix
Joined: 6/11/2014(UTC) Posts: 2 Location: philippines
hi, i'm planning to buy an ATEM TVS for my hardware, of course I will be using vMix for my video switcher, is it possible to control all the inputs and outputs of the TVS on the vMix?if yes, how can i do that?
thanks
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
tonypett wrote:hi, i'm planning to buy an ATEM TVS for my hardware, of course I will be using vMix for my video switcher, is it possible to control all the inputs and outputs of the TVS on the vMix?if yes, how can i do that?
thanks Do a search, there are some posts about it......did not read any of them, but I saw them
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
thanks I have a ATEM TVS and I use it with vMix but I have to change the cameras using the ATEM software control via another PC Laptop or iPad.
So just to be clear, no, you can't control the TVS with Vmix. They are completely separate devices.
If you want to mix on a computer with vmix you have to get inputs for whatever you're planning to use, hdmi or sdi capture cards or whatever, you can't use any of the ATEM's for that.
You can input the mixed output from the ATEM into vmix, again with an hdmi or sdi capture card.
Joined: 12/29/2013(UTC) Posts: 54 Location: Mississauga, Canada
Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
If you have some software development skills (or money to hire someone to do it), you could create a custom application that interfaces with both the vMix API and the ATEM SDK. That application could then control both vMix and the TVS. The vMix part is really easy and the TVS control is more complicated, but I think it could still be done. Check out http://atemuser.com/foru...vision-mixers/developers for more information on programming for the TVS.
thanks to everyone who answered, its rather hard for me to find capture cards here in the Philippines,the only available equipment here is the ATEM TVS, looks like I can't use vMix as my video mixer.
