nandhitv
#1 Posted : Saturday, June 7, 2014 4:21:33 AM(UTC)
nandhitv
If i input source from media player hd
thay live video playing on media player hd software
how to input to vmix without desktop capture because desktop capture quality low.
there is a way to input like fraps recording ?
Sry for my bad english
fordry
#2 Posted : Thursday, July 17, 2014 3:59:13 AM(UTC)
fordry
best way would be to get a capture card and splitter. Split off your output so it goes to your monitor and to the capture card and then use that capture source in vmix.
madness
#3 Posted : Thursday, July 17, 2014 2:41:37 PM(UTC)
madness
I use this to capture full screen resolution. It's a 2 PC solution though.
http://www.avermedia-usa...roductDetail.aspx?Id=503
The output of my laptop goes to the capture card on the second PC that runs vMix, and I preview and mix it there. I had to do a sound calibration on the laptop output to re-sync the audio and video after the induced latency however. I'm not sure you can do that with media player, but perhaps with the audio delay capability of vmix.
