nandhitv
#1 Posted : Saturday, June 7, 2014 4:21:33 AM(UTC)
nandhitv
If i input source from media player hd
thay live video playing on media player hd software
how to input to vmix without desktop capture because desktop capture quality low.
there is a way to input like fraps recording ?
Sry for my bad english
fordry
#2 Posted : Thursday, July 17, 2014 3:59:13 AM(UTC)
fordry
best way would be to get a capture card and splitter. Split off your output so it goes to your monitor and to the capture card and then use that capture source in vmix.
madness
#3 Posted : Thursday, July 17, 2014 2:41:37 PM(UTC)
madness
I use this to capture full screen resolution. It's a 2 PC solution though.
http://www.avermedia-usa...roductDetail.aspx?Id=503
The output of my laptop goes to the capture card on the second PC that runs vMix, and I preview and mix it there. I had to do a sound calibration on the laptop output to re-sync the audio and video after the induced latency however. I'm not sure you can do that with media player, but perhaps with the audio delay capability of vmix.
Guest (4)
