911pro
#1 Posted : Wednesday, June 24, 2020 2:33:44 AM(UTC)
911pro
Is there a shortcut to switch between the 4 shots in a multiview? For example, if I simply click on a shot it will cut or transition to that look. However, I'd love to assign a keystroke to each of those four looks if possible.
#2 Posted : Wednesday, June 24, 2020 2:55:01 AM(UTC)
Multiview or virtual set ?
VS -> SetZoom
911pro
#3 Posted : Wednesday, June 24, 2020 2:59:10 AM(UTC)
911pro
Virtual set, sorry.
#4 Posted : Wednesday, June 24, 2020 3:01:48 AM(UTC)
SetZoom
#5 Posted : Wednesday, June 24, 2020 3:08:15 AM(UTC)
SelectIndex is the one you're looking for
They're all listed here btw, you don't need us to find available shortcuts
https://www.vmix.com/hel...utFunctionReference.html
911pro
#6 Posted : Wednesday, June 24, 2020 7:53:43 AM(UTC)
911pro
SelectIndex for the win. Thank you DWAM.. Worked perfectly.
#7 Posted : Wednesday, June 24, 2020 8:09:39 AM(UTC)
in fact both work
SetZoom will cut to the position
SelectIndex will zoomanimate to the position
#8 Posted : Wednesday, June 24, 2020 8:48:54 AM(UTC)
in fact both work
True! 2 options is better than only 1 ! vMix's great !
