Shortcut for Multiview Shots?
Joined: 6/24/2020(UTC) Posts: 9  Location: New England
Is there a shortcut to switch between the 4 shots in a multiview? For example, if I simply click on a shot it will cut or transition to that look. However, I'd love to assign a keystroke to each of those four looks if possible.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Multiview or virtual set ?
VS -> SetZoom
Originally Posted by: DWAM  SelectIndex for the win. Thank you DWAM.. Worked perfectly.
in fact both work
SetZoom will cut to the position SelectIndex will zoomanimate to the position
Quote:in fact both work
SetZoom will cut to the position SelectIndex will zoomanimate to the position True! 2 options is better than only 1 ! vMix's great !
