When vMix is started then the installer is invoked
Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
HELP! I connected my X32 mixer to my PC and tried to change the audio output harware in vMix. Then I had to restart vMix. However vMix did not start anymore. Instead it seems to invoke some kind of installer. Unfortunately the "Preparing to install" window is displayed for ages and I cannot cancel this. Already tried to reinstall vMix, even after a full uninstallation, but this all did not help.
Anybody a suggestion of what to do now?
Thanks, Peter.
Have you tried disconnecting the x32 and then attempted to open vMix?
Originally Posted by: stigaard  Have you tried disconnecting the x32 and then attempted to open vMix? Yes, also tried that. Thanks. It turns out that there is something wrong in the windows user specific data. When I create a new Windows user I can startup vMix perfectly fine. Hopefully some of the vMix developers can tell me which file in the windows user specific data I have to cleanup. I guess it's a temp file created to provide vMix startup parameters in case you make a change in one of the settings that requires a restart. Thanks, Peter.
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
The vMix application does not have any installer or other functionality in it at all, so it sounds like some other program or component on the computer is hijacking the vMix installation, you may be able to see this by running the vMix Diagnostics application.
Martin vMix
Originally Posted by: admin  The vMix application does not have any installer or other functionality in it at all, so it sounds like some other program or component on the computer is hijacking the vMix installation, you may be able to see this by running the vMix Diagnostics application.
Hi Martin, To run the diagnostics tool I need to run vMix first, but I cannot. During the vMix startup splash screen, an installer is invoked. I'm not sure if this is the vMix installer. It looks like an issue that is related to a very specific Windows user. Would you be able to tell how I can cleanup all the files that are created to be taken into account the very next startup of vMix (i.e. after a settings change was made that needs a restart) Thanks, Peter.
Originally Posted by: elvis55  It looks like that is a generic Windows cleanup procedure. I think I need it specifically for vMix. Thanks anyway. Peter.
you can run the vMixDiagnostics.exe direct from the vmix program folder without starting vmix
Thanks: 4 times Was thanked: 10 time(s) in 8 post(s)
Originally Posted by: petervk  an installer is invoked. I'm not sure if this is the vMix installer. I would try also to identify whats that window... Try to check task manager or something to identify whats that app, if its a windows dependency or in worst case, a virus trying to do something...
Quote:you can run the vMixDiagnostics.exe direct from the vmix program folder without starting vmix I did, but no problems were reported. Quote:I would try also to identify whats that window... Try to check task manager or something to identify whats that app, if its a windows dependency or in worst case, a virus trying to do something I was not able to identify the window. Eventually I replaced the Windows user profile and the incident did not happen again. Peter.
did you also try 23.0.0.58 ?
