	NDI Video roll auto play when taken on another vmix machine
                I have two vmix's I use one (vmix1) to cut cameras and audio, the other (vmix2) to handle video broll and records. I have the NDI output turned on for vmix 2  Mobdro Kodi bluehost and have added it as an input on vmix 1. I would like it so when I cut from a camera on vmix 1, to the NDI output that it auto rolls for me, instead of having to do a manual roll on vmix2 and risking a freeze on-air. I was playing around with triggers but couldn't get it going. This would similar to a GPI roll and take in the broadcast world Thoughts? Suggestions?
 Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
                Put the code below into a script.  Set up a trigger OnTransitionIn of the source of the other vMix that runs this script.  Bam, just like a General Purpose Interface. Code:Using client as new WebClient
    dim result = client.UploadString("http://[Private IP address of the other vMix]:8088/api/", "Function=Play&Input=-1")
End Using
 By the way, I think the plural of vMix is vMixen.
              1 user thanked Geoff B for this useful post.
