KaidenJustin
#1 Posted : Tuesday, June 16, 2020 10:11:55 PM(UTC)
KaidenJustin
I have two vmix's
I use one (vmix1) to cut cameras and audio, the other (vmix2) to handle video broll and records.
I have the NDI output turned on for vmix 2 Mobdro Kodi bluehost and have added it as an input on vmix 1. I would like it so when I cut from a camera on vmix 1, to the NDI output that it auto rolls for me, instead of having to do a manual roll on vmix2 and risking a freeze on-air. I was playing around with triggers but couldn't get it going.
This would similar to a GPI roll and take in the broadcast world
Thoughts? Suggestions?
Geoff B
#2 Posted: : Friday, June 19, 2020 6:27:02 AM(UTC)
Geoff B
Put the code below into a script. Set up a trigger OnTransitionIn of the source of the other vMix that runs this script. Bam, just like a General Purpose Interface.
Code:
Using client as new WebClient
    dim result = client.UploadString("http://[Private IP address of the other vMix]:8088/api/", "Function=Play&Input=-1")
End Using
By the way, I think the plural of vMix is vMixen.
thanks 1 user thanked Geoff B for this useful post.
nikosman88 on 11/29/2022(UTC)
