froggio
#1 Posted : Wednesday, June 10, 2020 4:45:47 AM(UTC)
froggio
I'm trying to stream out of vMix to Brightcove via RTMP. When I start the stream it connects momentarily and then gives me the error [rtmp @ 04ed9ae0] Server error: Validation failed. The same machine using OBS Studio and identical settings can stream to Brightcove without any issues.
PC Build:
Intel i5-4670K
24GB RAM
Gigabyte nVidia GTX 1650 Super
Windows 10 Pro 64-bit
Samsung 860Pro SSD for System
WD Raptor 10k RPM for storage
Stream settings:
4000kbps
1280x720
AAC 128kbps
Profile: Baseline
Level: 3.1
Preset: veryfast
Keyframe: 2sec
Strict CBR: Yes
Vmix: 23.0.0.57 (I tried 23.0.0.54 and received the same error message)
streaming1 20200609-130541.txt (3kb) downloaded 9 time(s).
Thank you for any help you can provide.
Frank
apocnz
#2 Posted : Sunday, June 14, 2020 5:01:43 PM(UTC)
apocnz
Groups:: Registered
Had same issue, ended up using FMLE /w Vmix Video/Audio output to stream
Found that Brightcove is pretty fussy. Can't stream more than 25/30fps to their server, after fiddling with vmix stream settings
and meeting their requirements, it worked.
Here's their stream info
https://live.support.bri...live-best-practices.html
