Server Error: Validation Failed
I'm trying to stream out of vMix to Brightcove via RTMP. When I start the stream it connects momentarily and then gives me the error [rtmp @ 04ed9ae0] Server error: Validation failed. The same machine using OBS Studio and identical settings can stream to Brightcove without any issues. PC Build: Intel i5-4670K 24GB RAM Gigabyte nVidia GTX 1650 Super Windows 10 Pro 64-bit Samsung 860Pro SSD for System WD Raptor 10k RPM for storage Stream settings: 4000kbps 1280x720 AAC 128kbps Profile: Baseline Level: 3.1 Preset: veryfast Keyframe: 2sec Strict CBR: Yes Vmix: 23.0.0.57 (I tried 23.0.0.54 and received the same error message)  streaming1 20200609-130541.txt (3kb) downloaded 9 time(s).Thank you for any help you can provide. Frank
Had same issue, ended up using FMLE /w Vmix Video/Audio output to stream Found that Brightcove is pretty fussy. Can't stream more than 25/30fps to their server, after fiddling with vmix stream settings and meeting their requirements, it worked. Here's their stream info https://live.support.bri...live-best-practices.html
