mavik
#1 Posted : Wednesday, June 10, 2020 2:12:10 AM(UTC)
mavik
The PTZ control is very basic. It does everything but it could be improved in my eyes.
#1 Be able to control (through) NDI. No IP config needed (like the Studio Monitor) So add NDI to device type.
#2 Add direction controls more in an analog style (like in Studio Monitor). The more you get off the center the fast the movement. Maybe a checkbox called analog will do this. Then you click on the middle point and drag to where you want it. Like a joystick or IDK how to explain this better.
Similar Topics
Virtual PTZ improvements: sync Pan-Tilt and Zoom, soft in/out, crop positioning using mouse (Feature Requests)
by MiOw 9/27/2019 4:58:21 PM(UTC)
