The PTZ control is very basic. It does everything but it could be improved in my eyes. #1 Be able to control (through) NDI. No IP config needed (like the Studio Monitor) So add NDI to device type. #2 Add direction controls more in an analog style (like in Studio Monitor). The more you get off the center the fast the movement. Maybe a checkbox called analog will do this. Then you click on the middle point and drag to where you want it. Like a joystick or IDK how to explain this better.
