jpearson
#1 Posted : Wednesday, June 10, 2020 2:05:27 AM(UTC)
jpearson
V 23
I have input a web source pointing to a google slide show. I am OK with entering my login credentials. Once login credentials added, the message says that the browser is not secured, therefore it never loads. Is there a better way to show a google slide show? I tried to download it as a PowerPoint, however, the formatting went to pieces. I was able to bring it into an input on Vmix.
#2 Posted : Wednesday, June 10, 2020 2:18:40 AM(UTC)
Just use your browser and use Desktop Capture (from vMix host) or NDI from another computer's browser (on the same network)
mavik
#3 Posted : Wednesday, June 10, 2020 9:52:54 PM(UTC)
mavik
If the powerpoint export is looking good you can present online from there and use it as web-input. I have been using this for years and vmix lately found this function useful as well.
