V 23 I have input a web source pointing to a google slide show. I am OK with entering my login credentials. Once login credentials added, the message says that the browser is not secured, therefore it never loads. Is there a better way to show a google slide show? I tried to download it as a PowerPoint, however, the formatting went to pieces. I was able to bring it into an input on Vmix.
Just use your browser and use Desktop Capture (from vMix host) or NDI from another computer's browser (on the same network)
Joined: 4/23/2017(UTC) Posts: 1,491  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
If the powerpoint export is looking good you can present online from there and use it as web-input. I have been using this for years and vmix lately found this function useful as well.
