Joined: 6/6/2020(UTC) Posts: 2  Location: London Thanks: 1 times
Hi All.
I'm just getting my head around vMix with a view to using it in an install.
Is it possible to set vmix up so on boot up of the machine the machine loads Vmix with a configured set of settings? I'm trying to make the system as fool proof as possible.
Thanks.
Michael
Yes it's possible like any other software in Windows, it's a windows feature
Been discussed in the forum already, use the search function to find these threads and the different solutions
open from windows directly calling a preset file
I can't quite remember how I did it, but try this....go to AppData > Roaming.> Microsoft > Windows > Start Menu > Programs > Startup, ....copy and paste vMix shortcut icon in that folder.......Now that will only launch vMix, but not the preset...you will have to create a shortcut for that preset, and place that in the folder, and omit the vMix shortcut...just the preset shortcut....I used to use Last, as I always used the same preset for a while....give that a try and please let us know how it turned out...
Hope that I helped you Joeboe
 1 user thanked Joeboe for this useful post.
Originally Posted by: Joeboe  I can't quite remember how I did it, but try this....go to AppData > Roaming.> Microsoft > Windows > Start Menu > Programs > Startup, ....copy and paste vMix shortcut icon in that folder.......Now that will only launch vMix, but not the preset...you will have to create a shortcut for that preset, and place that in the folder, and omit the vMix shortcut...just the preset shortcut....I used to use Last, as I always used the same preset for a while....give that a try and please let us know how it turned out...
Hope that I helped you Joeboe Thanks Joeboe and all the rest for the speedy replies!
Originally Posted by: Joeboe  I you will have to create a shortcut for that preset one can open a vMix strait form the the setup file !! no need for separate shortcut or instruction
