mjsanders5
#1 Posted : Saturday, June 6, 2020 2:51:11 AM(UTC)
mjsanders5
Hi All.
I'm just getting my head around vMix with a view to using it in an install.
Is it possible to set vmix up so on boot up of the machine the machine loads Vmix with a configured set of settings? I'm trying to make the system as fool proof as possible.
Thanks.
Michael
#2 Posted : Saturday, June 6, 2020 3:04:10 AM(UTC)
Yes it's possible like any other software in Windows, it's a windows feature
Been discussed in the forum already, use the search function to find these threads and the different solutions
#3 Posted : Saturday, June 6, 2020 3:10:25 AM(UTC)
open from windows directly calling a preset file
Joeboe
#4 Posted : Saturday, June 6, 2020 3:45:43 AM(UTC)
Joeboe
I can't quite remember how I did it, but try this....go to AppData > Roaming.> Microsoft > Windows > Start Menu > Programs > Startup, ....copy and paste vMix shortcut icon in that folder.......Now that will only launch vMix, but not the preset...you will have to create a shortcut for that preset, and place that in the folder, and omit the vMix shortcut...just the preset shortcut....I used to use Last, as I always used the same preset for a while....give that a try and please let us know how it turned out...
Hope that I helped you
Joeboe
thanks 1 user thanked Joeboe for this useful post.
mjsanders5 on 6/6/2020(UTC)
mjsanders5
#5 Posted : Saturday, June 6, 2020 4:00:19 AM(UTC)
mjsanders5
Joeboe
Thanks Joeboe and all the rest for the speedy replies!
#6 Posted : Saturday, June 6, 2020 4:19:10 AM(UTC)
I you will have to create a shortcut for that preset
one can open a vMix strait form the the setup file !! no need for separate shortcut or instruction
