I added about 20 short MP4 scenic videos to my vmix. It caused my GPU mem % at the bottom to go to 100%. I then found that I can select to use "High Input Performance Mode" and it took it down to 55%. Here is my questions. 1. Why did my GPU mem increase so much just adding inputs? 2. Is there a better way to add the/ use them with out filling up my GPU Memory? 3 Is there a problem with the GPU Memory % being high?
Thanks in advance.
PS. They are just 15 to 20 sec scenic clips that call one after the other to have a nice preshow before we start our service.
Joe
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
Joined: 1/25/2019(UTC) Posts: 327  Thanks: 23 times Was thanked: 82 time(s) in 62 post(s)
use Video list, that uses only one input and solves your problem. Video List
I have never been convinced that this works right. We use video delay extensively for replay. It saves to a list. With every save the gpu percentage goes up even if in a list. Even if you delete the list input it pegs at 100percent.
So I just starting ignoring it. I have ever dropped a frame because of it and render times are below 7ms.
