Davteks
#1 Posted : Tuesday, June 2, 2020 9:01:45 AM(UTC)
Davteks
I added about 20 short MP4 scenic videos to my vmix. It caused my GPU mem % at the bottom to go to 100%. I then found that I can select to use "High Input Performance Mode" and it took it down to 55%. Here is my questions.
1. Why did my GPU mem increase so much just adding inputs?
2. Is there a better way to add the/ use them with out filling up my GPU Memory?
3 Is there a problem with the GPU Memory % being high?
Thanks in advance.
PS. They are just 15 to 20 sec scenic clips that call one after the other to have a nice preshow before we start our service.
Joe
#2 Posted : Tuesday, June 2, 2020 9:36:20 AM(UTC)
@ Davteks
Please have a look at this Knowledge base article:
https://www.vmix.com/kno...n-in-the-vmix-status-bar
Peter1000
#3 Posted : Tuesday, June 2, 2020 4:56:47 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
use Video list, that uses only one input and solves your problem.
Video List
kjones9999
#4 Posted : Wednesday, June 3, 2020 5:45:05 AM(UTC)
kjones9999
I have never been convinced that this works right. We use video delay extensively for replay. It saves to a list. With every save the gpu percentage goes up even if in a list. Even if you delete the list input it pegs at 100percent.
So I just starting ignoring it. I have ever dropped a frame because of it and render times are below 7ms.
