vMix Call
My own logo in vMix call link?
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Hi you all!
I wonder if it is possible to change vMix logo from the link I send to the callers in order to use mine, like using vMix Call like a "white brand". Would it be possible in furhter updates?
Thanks!
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
 1 user thanked Simsyuk for this useful post.
Joined: 4/6/2019(UTC) Posts: 95  Location: Florida Thanks: 10 times Was thanked: 13 time(s) in 11 post(s)
First and foremost I am not a web designer at all
BUT
could you not make your own domain/webpage with the data entry fields, and when they click 'connect' on your page it fills the fields in the vmixcall.com page without the user ever seeing it?
 1 user thanked KnKproductions for this useful post.
Joined: 10/10/2019(UTC) Posts: 65   Location: Düsseldorf Thanks: 5 times Was thanked: 16 time(s) in 9 post(s)
Hi, just build your own Page with Inpzut fields and this Script: Quote:
<!-- Code VMix --> <script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script> <script type="text/javascript"> $(document).ready(function(){ $('#vmixform').submit(function(){ var urlNumber = $('#vmixNumber').val() var urlName = $('#vmixName').val() var urlString = urlNumber + "&Name=" + urlName window.location = "https://www.vmixcall.com/call.aspx?Key=" + urlString; return false; }); }); </script>
For the text fields Quote: <input type="text" class="form-control" id="vmixName" placeholder="Name" name="vmixName" required>
<input type="text" class="form-control" id="vmixNumber" placeholder="Password vMix Call" name="vmixNumber" required>
 4 users thanked Follo for this useful post.
Thanks a lot guys for your help. I'll try it out asap.
Thanks again!
Adding your +1 to this feature request is probably the best thing to do to see this feature natively implemented in vMix. https://forums.vmix.com/...-VmixCall-in-white-labelThis code provided above will work but the vMix logo will still be visible if a call is disconnected by choice or failure. So if your idea is to hide completely the vMixcall website, it's impossible.
vMix Call
