RC_31
#1 Posted : Friday, May 29, 2020 6:42:12 PM(UTC)
RC_31
Hi you all!
I wonder if it is possible to change vMix logo from the link I send to the callers in order to use mine, like using vMix Call like a "white brand". Would it be possible in furhter updates?
Thanks!
Simsyuk
#2 Posted : Friday, May 29, 2020 7:42:20 PM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Have you added this to the request section? https://forums.vmix.com/topics/4-Feature-Requests
thanks 1 user thanked Simsyuk for this useful post.
RC_31 on 6/4/2020(UTC)
KnKproductions
#3 Posted : Saturday, May 30, 2020 3:10:30 AM(UTC)
KnKproductions
First and foremost I am not a web designer at all
BUT
could you not make your own domain/webpage with the data entry fields, and when they click 'connect' on your page it fills the fields in the vmixcall.com page without the user ever seeing it?
thanks 1 user thanked KnKproductions for this useful post.
Follo
#4 Posted : Monday, June 1, 2020 10:49:39 PM(UTC)
Follo
Germany
Was thanked: 16 time(s) in 9 post(s)
Hi, just build your own Page with Inpzut fields and this Script:
<!-- Code VMix -->
<script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script>
<script type="text/javascript">
$(document).ready(function(){
$('#vmixform').submit(function(){
var urlNumber = $('#vmixNumber').val()
var urlName = $('#vmixName').val()
var urlString = urlNumber + "&Name=" + urlName
window.location = "https://www.vmixcall.com/call.aspx?Key=" + urlString;
return false;
</script>
For the text fields
<input type="text" class="form-control" id="vmixName" placeholder="Name" name="vmixName" required>
<input type="text" class="form-control" id="vmixNumber" placeholder="Password vMix Call" name="vmixNumber" required>
thanks 4 users thanked Follo for this useful post.
ask on 6/2/2020(UTC), KnKproductions on 6/3/2020(UTC), greggibson on 6/4/2020(UTC), RC_31 on 6/4/2020(UTC)
RC_31
#5 Posted : Thursday, June 4, 2020 6:26:00 PM(UTC)
RC_31
Thanks a lot guys for your help. I'll try it out asap.
Thanks again!
#6 Posted : Thursday, June 4, 2020 8:27:37 PM(UTC)
Adding your +1 to this feature request is probably the best thing to do to see this feature natively implemented in vMix.
https://forums.vmix.com/...-VmixCall-in-white-label
This code provided above will work but the vMix logo will still be visible if a call is disconnected by choice or failure. So if your idea is to hide completely the vMixcall website, it's impossible.
