helldriver
#1 Posted : Tuesday, May 26, 2020 8:52:27 AM(UTC)
helldriver
Poland
Hello vMix world.
I have a strange problem with vMix.
My vMix is dropping frames on "virtual" causing freezed frames on my streams.
My configuration is:
2x Xeon e5 2667 v3 8CORE
128gb Ram
2x ssd nvme on pcie
Nvidia Quatro RTX4000
1x BMD Decklink duo2
1x double 10gbe card
Attached you can find screenshots i took showing growing number of dropped frames as well as you can see on the link below.
Glitches starting from the very beginning and are visible/hearable throughout the entire stream.
I`m using 3 sdi inputs and one external on duo2 card and 4 vmix calls.
My system performance window shows 28gb of used ram, 1,2gb used GPU memory, 30% GPU , up to 1% of disk speed.
Any ideas ?
Thanks in advance Bez tytulu2.png (3,194kb) downloaded 8 time(s). Bez tytulu.png (3,203kb) downloaded 0 time(s).
