                Hello vMix world. I have a strange problem with vMix. My vMix is dropping frames on "virtual" causing freezed frames on my streams. My configuration is: 2x Xeon e5 2667 v3 8CORE 128gb Ram 2x ssd nvme on pcie Nvidia Quatro RTX4000 1x BMD Decklink duo2 1x double 10gbe card Attached you can find screenshots i took showing growing number of dropped frames as well as you can see on the link below. Glitches starting from the very beginning and are visible/hearable throughout the entire stream. I`m using 3 sdi inputs and one external on duo2 card and 4 vmix calls. My system performance window shows 28gb of used ram, 1,2gb used GPU memory, 30% GPU , up to 1% of disk speed. Any ideas ? Thanks in advance   Bez tytulu2.png  (3,194kb) downloaded 8 time(s).  Bez tytulu.png  (3,203kb) downloaded 0 time(s).
