Hi, I am in a trial period withvmix right now but I think I will be buying at the end of the trial period. Question. I run 5 monitors and, no matter the configuration I run in the windows display, only the 4 monitors on my desk will take the fullscreen display. I have swaped inputs, adjusted numbers within the display setting and everything in between...has anyone else had this issue or is there something simple I am missing??
I want to run this 5th screen as the monitor for guests that come in my studio...the other 4 are for me and my production while the show runs. Thanks in advance!!!
Greg
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
you can use HDMI splitters
you can use EXTERNAL outs
you can use NDI
you can use HDMI to ETH converters
and I might forget some of the options available...
