 Joined: 5/19/2020(UTC) Posts: 4  Location: Cleveland |
                Hi, I am in a trial period withvmix right now but I think I will be buying at the end of the trial period.  Question.  I run 5 monitors and, no matter the configuration I run in the windows display, only the 4 monitors on my desk will take the fullscreen display.  I have swaped inputs, adjusted numbers within the display setting and everything in between...has anyone else had this issue or is there something simple I am missing??
 I want to run this 5th screen as the monitor for guests that come in my studio...the other 4 are for me and my production while the show runs.  Thanks in advance!!!
 Greg
 Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, FranceThanks: 243 timesWas thanked: 796 time(s) in 590 post(s)
                you can use HDMI splitters
 you can use EXTERNAL outs
 you can use NDI
 you can use HDMI to ETH converters
 and I might forget some of the options available...
