carlofornasari
#1 Posted : Monday, May 18, 2020 10:33:45 AM(UTC)
carlofornasari
Hi there,
Would we be able to put labels on audio mix busses and video outputs?
It's super easy to get them mixed up when you have seperate returns for some callers, or other feeds into other systems.
Many thanks!
Carlo
gzifcak
#2 Posted : Tuesday, May 19, 2020 1:56:31 AM(UTC)
gzifcak
+1
or even better for my use: show the name of the source on the output, so that if you switch the source the name gets updated
#3 Posted : Tuesday, May 19, 2020 2:02:22 AM(UTC)
Originally Posted by: gzifcak Go to Quoted Post
+1
The API XML can tell you which input nr is active (output)
That same API XML can tell you the title of that input
#4 Posted : Tuesday, May 19, 2020 2:06:26 AM(UTC)
Originally Posted by: carlofornasari Go to Quoted Post
Hi there,
Many thanks!
Carlo
the labels on the inputs and corresponding audio have the same name
one can modify these names
one can pull these names to do whatever one wants to do with them , like in a title etc
