Joined: 7/5/2019(UTC) Posts: 28  Location: Sydney Was thanked: 5 time(s) in 4 post(s)
Hi there,
Would we be able to put labels on audio mix busses and video outputs? It's super easy to get them mixed up when you have seperate returns for some callers, or other feeds into other systems.
Many thanks!
Carlo
Joined: 4/26/2020(UTC) Posts: 38  Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
+1
or even better for my use: show the name of the source on the output, so that if you switch the source the name gets updated
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: gzifcak  +1
or even better for my use: show the name of the source on the output, so that if you switch the source the name gets updated The API XML can tell you which input nr is active (output) That same API XML can tell you the title of that input
Many thanks!
Carlo the labels on the inputs and corresponding audio have the same name one can modify these names one can pull these names to do whatever one wants to do with them , like in a title etc
