moerkel
#1 Posted : Friday, May 15, 2020 2:53:00 AM(UTC)
moerkel
Ireland
I am using the flash input to get severl inbound RTMP streams.
Incoming rtmp connections may be offline for a few minutes, which is expected.
I noticed that a message "Media Playback Error" is flashing for a few mintues when the steam is offline.
While it is flashing the connection is automatically re-established once the rtmp input is back online.
After a few minutes the message "Media Playback Error" stops flashing and the connection is not re-stablished anymore if the rtmp input is back online.
Is there any configuration I can change for this timeout?
elvis55
#2 Posted : Friday, May 15, 2020 3:58:49 AM(UTC)
elvis55
Switzerland
NOTE: At this feature relies on Adobe Flash Player for support, a number of restrictions and limitations, particularly with audio apply.
To bring in RTMP streams, consider using the Stream input instead with the VLC dropdown option.
Flash
try it
Stream / SRT
VLC
The VLC option uses the free VLC Media Player software to connect to the stream.
This requires installing a special version of VLC which can be downloaded and installed from here:
vMix currently supports only RTMP, UDP, RTP, RTSP and TS streams using this method.
Other stream types such as HLS and M3U8 are not supported.
moerkel
#3 Posted : Friday, May 15, 2020 9:23:11 PM(UTC)
moerkel
Ireland
Flash
try it
Stream / SRT
VLC
Thank you elvis55 for your reply.
When testing Flash as input I did not find any issue with the audio. Would you know what I would need to watch out for?
I tried to use the VLC plugin first, but found out that the "Re-Connection" does not work at all this way.
I am more than happy to change to VLX, if I could get this working.
moerkel
#4 Posted : Friday, May 15, 2020 9:25:41 PM(UTC)
moerkel
Ireland
I am more than happy to change to VLC, if I could get this working.
