I am using the flash input to get severl inbound RTMP streams. Incoming rtmp connections may be offline for a few minutes, which is expected.
I noticed that a message "Media Playback Error" is flashing for a few mintues when the steam is offline. While it is flashing the connection is automatically re-established once the rtmp input is back online.
After a few minutes the message "Media Playback Error" stops flashing and the connection is not re-stablished anymore if the rtmp input is back online.
Is there any configuration I can change for this timeout?
NOTE: At this feature relies on Adobe Flash Player for support, a number of restrictions and limitations, particularly with audio apply. To bring in RTMP streams, consider using the Stream input instead with the VLC dropdown option. Flashtry it Stream / SRTVLC The VLC option uses the free VLC Media Player software to connect to the stream. This requires installing a special version of VLC which can be downloaded and installed from here: vMix currently supports only RTMP, UDP, RTP, RTSP and TS streams using this method. Other stream types such as HLS and M3U8 are not supported.
Originally Posted by: elvis55  NOTE: At this feature relies on Adobe Flash Player for support, a number of restrictions and limitations, particularly with audio apply. To bring in RTMP streams, consider using the Stream input instead with the VLC dropdown option. Flashtry it Stream / SRTVLC The VLC option uses the free VLC Media Player software to connect to the stream. This requires installing a special version of VLC which can be downloaded and installed from here: vMix currently supports only RTMP, UDP, RTP, RTSP and TS streams using this method. Other stream types such as HLS and M3U8 are not supported. Thank you elvis55 for your reply. When testing Flash as input I did not find any issue with the audio. Would you know what I would need to watch out for? I tried to use the VLC plugin first, but found out that the "Re-Connection" does not work at all this way. I am more than happy to change to VLX, if I could get this working.
I tried to use the VLC plugin first, but found out that the "Re-Connection" does not work at all this way. I am more than happy to change to VLC, if I could get this working.
