nandhitv
#1 Posted : Tuesday, May 20, 2014 7:45:34 AM(UTC)
nandhitv
How to extend this only 4 have
#2 Posted : Tuesday, May 20, 2014 10:15:14 AM(UTC)
@ nandhitv
I can only assume you are attempting to load an image sequence, yes?
To do so, when adding the image input, check the "Image Sequence" tick box in the pop-up window.
That will load all the images in the sequence that are in that folder.
nandhitv
#3 Posted : Tuesday, May 20, 2014 11:02:38 AM(UTC)
nandhitv
IceStream wrote:
@ nandhitv
Im not speaking about a sequence im telling about this one
#4 Posted : Tuesday, May 20, 2014 12:32:36 PM(UTC)
Yes, there are only 4 overlay channels as downstream keys.
But you can "extend" so to speak by using the "Multi View" feature in settings for each input, thereby giving you 4 overlays for each input thereby increasing the possibilities to 8 overlays on one input if set up properly.
