How to extend this only 4 have
@ nandhitv I can only assume you are attempting to load an image sequence, yes? To do so, when adding the image input, check the "Image Sequence" tick box in the pop-up window. That will load all the images in the sequence that are in that folder.
IceStream wrote:@ nandhitv I can only assume you are attempting to load an image sequence, yes? To do so, when adding the image input, check the "Image Sequence" tick box in the pop-up window. That will load all the images in the sequence that are in that folder.
Ice Im not speaking about a sequence im telling about this one
Yes, there are only 4 overlay channels as downstream keys. But you can "extend" so to speak by using the "Multi View" feature in settings for each input, thereby giving you 4 overlays for each input thereby increasing the possibilities to 8 overlays on one input if set up properly.
