NDI
SKype NDI Multicorder Issues
Tried to record 4x Skype NDI's into a multicorder (4Mbps MP4), with fault tolerance turned on & kept getting record time's restart to zero and alot of clips. Not sure why this is happening
System Specs: Intel(R) Core(TM) i9-10920X CPU @ 3.50GHz NVIDIA GeForce RTX 2080 Ti 128 GB RAM
Joined: 10/25/2012(UTC) Posts: 179 Location: Barbados
I am also having this problem which is quite frustrating. Each Skype NDI source is being broken up into multiple clips in Multicorder that basically makes it impractical to use. I was unsure if this is a bug, but I have given up using multicorder with Skype. It would good to know if this is a bug or related to some other issue.
Maxi
AFAIK This is caused by Skype sending a VBR stream. I believe that multicorder will see a change in the bandwidth/resolution as a break and will therefore create a new file. There is an explanation of this somewhere on this forum. In other words not a bug, works as designed.
Have a look at this KB article. Even though it is for vMixCall, it should also apply: https://www.vmix.com/knowledgebase/article.aspx/240/multiple-recording-files-when-using-multicorder-with-vmix-call
Thanks ASK, I hadn't seen this info before, I will give it a look to see if that solves the multiple file problem.
Maxi
NDI
