Hardware Compatibility
Behringer XTouch Compact - Template and Activator Settings
Joined: 5/10/2020(UTC) Posts: 1  Location: Los Angeles
The Behringer XTouch Compact has touch sensitive faders that correspond with multiple Note numbers. So, when I clicked FIND in the shortcuts menu and moved fader 1, vMix displayed the Note number for the fader's touch sensitivity. Because, I was still touching the fader. That is Note 101. And, when I released the fader, Note 1 was briefly displayed. So, the shortcut for fader 1 should reference Note 1. MIDIControlChange Channel: 1 / Note: 1 Type: Default Input: 1 Checkmark on "Assign Shortcut to Input Number" Below is a link to the shortcuts and activators that I programmed for the Behringer XTouch Compact. https://www.dropbox.com/..._XTouch_Compact.zip?dl=0JS
Joined: 9/17/2020(UTC) Posts: 18  Location: Leeds Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
Thank you for this. The template is really helpful and worked first time. Did you manage to get it working so that if you changed the fader volume in vmix it reflected onto the compact? Using your template it seems to freeze the ability to change in vmix. It is not a necessity but interested to know all the same.
