JStevensJr
#1 Posted : Sunday, May 10, 2020 8:01:04 AM(UTC)
JStevensJr
The Behringer XTouch Compact has touch sensitive faders that correspond with multiple Note numbers. So, when I clicked FIND in the shortcuts menu and moved fader 1, vMix displayed the Note number for the fader's touch sensitivity. Because, I was still touching the fader. That is Note 101. And, when I released the fader, Note 1 was briefly displayed. So, the shortcut for fader 1 should reference Note 1.
MIDIControlChange
Channel: 1 / Note: 1
Type: Default
Input: 1
Checkmark on "Assign Shortcut to Input Number"
Below is a link to the shortcuts and activators that I programmed for the Behringer XTouch Compact.
https://www.dropbox.com/..._XTouch_Compact.zip?dl=0
JS
njfeathe85
#2 Posted : Wednesday, January 27, 2021 12:02:00 AM(UTC)
njfeathe85
Thank you for this. The template is really helpful and worked first time. Did you manage to get it working so that if you changed the fader volume in vmix it reflected onto the compact? Using your template it seems to freeze the ability to change in vmix. It is not a necessity but interested to know all the same.
