MuseTx
#1 Posted : Saturday, May 9, 2020 2:00:14 AM(UTC)
MuseTx
I'd like to see shortcuts stay vMix show file specific.
For example...
I do a weekly stream with several set shortcuts mapped to my Streamdeck XL.
I occasionally do one-off streams which require different shortcuts.
In the one-off stream I did last night, I moved\removed many shortcuts from my weekly stream so they couldn't interfere with what I was
doing... I saved the show file. It was great.
This morning, when I'm trying to prep for my weekly stream, I opened my original template show file and all the shortcuts which had been there
are now gone\changed to the shorcuts I made for my one-off show.
So, if I create shortcuts for show A, show B, and show C, those show-specific shortcuts should be available when I load the show file.
#2 Posted : Saturday, May 9, 2020 2:05:06 AM(UTC)
moved in vMix or SD ?
if vMix should save (export) settings
xaver
#3 Posted : Saturday, May 9, 2020 2:31:26 AM(UTC)
xaver
AFAIK
if you tick the "Local Shortcut" it would be saved only in that preset
