Feature Requests
Feature Request - Keep Shortcuts Show-file Specific
Joined: 3/10/2020(UTC) Posts: 3  Location: Fort Worth
I'd like to see shortcuts stay vMix show file specific.
For example...
I do a weekly stream with several set shortcuts mapped to my Streamdeck XL.
I occasionally do one-off streams which require different shortcuts.
In the one-off stream I did last night, I moved\removed many shortcuts from my weekly stream so they couldn't interfere with what I was doing... I saved the show file. It was great.
This morning, when I'm trying to prep for my weekly stream, I opened my original template show file and all the shortcuts which had been there are now gone\changed to the shorcuts I made for my one-off show.
So, if I create shortcuts for show A, show B, and show C, those show-specific shortcuts should be available when I load the show file.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
moved in vMix or SD ?
if vMix should save (export) settings
AFAIK if you tick the "Local Shortcut" it would be saved only in that preset
Feature Requests
