Vince Beck
#1 Posted : Sunday, May 3, 2020 3:47:31 AM(UTC)
Vince Beck
I keep seeing all these pretty elaborate setups for Zoom in/out of Vmix.
My setup:
To Zoom: External out to AJA UTap to Zoom computer as zoom input.
To Vmix: NDI Input screen capture with Vmix desktop capture. No particular audio change.
I tested and so far everything seems to work without feed back between vmix call and Zoom call.
Am I missing something that might bite me at some point??
screamn
#2 Posted : Friday, May 22, 2020 6:27:25 AM(UTC)
screamn
Good for you Vince, I'm glad this 'easy' approach is working for you. I'm trying the same kind of setup and I can bring in the Zoom video but no audio comes in. What are your audio settings?
Vince Beck
#3 Posted : Friday, May 22, 2020 6:59:54 AM(UTC)
Vince Beck
I forgot, you also need to install virtual audio cable on the Zoom machine. https://www.vb-audio.com/Cable/
That should be it.
