DynamoBen
#1 Posted : Wednesday, April 29, 2020 6:00:13 AM(UTC)
DynamoBen
Was thanked: 13 time(s) in 3 post(s)
I have a slides input and wanted to create a second input that was half the size and had choromakey enable. While I can create the input via multview I can't pick a key color with the eyedropper. Where am I going wrong?
dmwkr
#2 Posted : Wednesday, April 29, 2020 6:24:33 AM(UTC)
dmwkr
You should create a virtual input instead of a Multiview: Right click on the settings cog icon of your slides input.
DynamoBen
#3 Posted : Wednesday, April 29, 2020 11:18:36 PM(UTC)
DynamoBen
Thanks! I'm moving things from another streaming application to vmix, so I'm trying to learn the workflow and vmix concepts. It's a bit of a daunting task.
