Smaller duplicate input with Chromakey not working
Thanks: 3 times Was thanked: 13 time(s) in 3 post(s)
I have a slides input and wanted to create a second input that was half the size and had choromakey enable. While I can create the input via multview I can't pick a key color with the eyedropper. Where am I going wrong?
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
You should create a virtual input instead of a Multiview: Right click on the settings cog icon of your slides input.
Thanks! I'm moving things from another streaming application to vmix, so I'm trying to learn the workflow and vmix concepts. It's a bit of a daunting task.
