Tone13
#1 Posted : Monday, April 27, 2020 9:24:04 PM(UTC)
Tone13
Hi all,
How can I send my caller a return feed with the Master Audio (Mix Minus) as per usual but also include a producers microphone which is from another vMix call that I have on audio bus D?
The list of return audio options is Main, Headphones or one audio bus only.
I'm sure it's simple, and I thought I could use the output settings to have Output 3 outputting Main and bus ABCD and then send the caller audio output 3, but output 3 audio is not an option to send to a vMix Caller.
Cheers
dmwkr
#2 Posted : Tuesday, April 28, 2020 12:18:54 AM(UTC)
dmwkr
You'd have to enable a new bus, route all the inputs you want the callers to hear (so probably all inputs routed to M + producers microphone) to that bus and use it as source for the callers.
Tone13
#3 Posted : Tuesday, April 28, 2020 6:52:25 AM(UTC)
Tone13
Yeah, that's how I've been doing it. Seems a bit long winded doing it that way so thought there must be an easier way.... Maybe not.
Shame I can't send them one of the audio outputs..... As they have the option of Main plus a bus.....
