vMix Call
Audio Outputs to Caller
Joined: 3/29/2020(UTC) Posts: 104  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
Hi all,
How can I send my caller a return feed with the Master Audio (Mix Minus) as per usual but also include a producers microphone which is from another vMix call that I have on audio bus D?
The list of return audio options is Main, Headphones or one audio bus only.
I'm sure it's simple, and I thought I could use the output settings to have Output 3 outputting Main and bus ABCD and then send the caller audio output 3, but output 3 audio is not an option to send to a vMix Caller.
Cheers
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
You'd have to enable a new bus, route all the inputs you want the callers to hear (so probably all inputs routed to M + producers microphone) to that bus and use it as source for the callers.
Originally Posted by: dmwkr  You'd have to enable a new bus, route all the inputs you want the callers to hear (so probably all inputs routed to M + producers microphone) to that bus and use it as source for the callers. Yeah, that's how I've been doing it. Seems a bit long winded doing it that way so thought there must be an easier way.... Maybe not. Shame I can't send them one of the audio outputs..... As they have the option of Main plus a bus.....
vMix Call
