Bug or Feature - SelectTitlePreset :)
Joined: 4/17/2020(UTC) Posts: 50  Location: Washington DC Thanks: 6 times Was thanked: 4 time(s) in 2 post(s)
Ok after working on this for two days I finally figured this out. I searched the docs, every FB group and post on this forum and it is not mentioned anywhere (I could find).
Problem: When using the SelectTitlePreset shortcut, values 1 and 2 do not select the first and second title.
Solution: The first title value MUST be 0 and the second title value is considered 1.
As a ex-programmer I get it, this is a typical binary approach. But for humans we would consider the first title to be #1 :)
Maybe this is documented some where and I missed it. Or maybe it is my configuration but either way this is not obvious.
