LeeL
#1 Posted : Saturday, April 25, 2020 3:24:52 AM(UTC)
LeeL
Ok after working on this for two days I finally figured this out.
I searched the docs, every FB group and post on this forum and it is not mentioned anywhere (I could find).
Problem:
When using the SelectTitlePreset shortcut, values 1 and 2 do not select the first and second title.
Solution:
The first title value MUST be 0 and the second title value is considered 1.
As a ex-programmer I get it, this is a typical binary approach. But for humans we would consider the first title to be #1 :)
Maybe this is documented some where and I missed it. Or maybe it is my configuration but either way this is not obvious.
