Markarkark
#1 Posted : Friday, April 24, 2020 10:42:04 AM(UTC)
Markarkark
I just downloaded the demo. I have been using ManyCam. I have numerous iphones that I would like to use as cameras. In the demo I have 4 inputs and can add 4 iphone inputs via VMix Call. It works really well so far. I would like to purchase the HD version for $350.00 but it says that VMix Calls are limited to 1. I am wondering if I am misreading this. I only ask because on the demo there are only 4 inputs and they can all connect to iphones.
ask
#2 Posted: : Friday, April 24, 2020 11:42:55 AM(UTC)
ask
You are not wrong. The functionality increases with the edition. The Trial version (free for 60 days) is for the Pro edition. So all functionality is available. Check out the comparison chart here: https://www.vmix.com/purchase/#comparisontable
#3 Posted : Friday, April 24, 2020 7:49:33 PM(UTC)
@ Markarkark
The Trial allows for up to 1000 Inputs (and 8 vMix Calls).
Perhaps you have mixed up the 4 Overlay buttons as "Input" buttons, they are actually for the dsk (Down Stream Key) for lower third graphic overlays and PiP windows as explained in this video:
Markarkark
#4 Posted : Sunday, April 26, 2020 7:31:51 AM(UTC)
Markarkark
Thank you I really appreciate it. This is a great program.
