vMix Call
Basic Questions about VMix Call
Joined: 4/24/2020(UTC) Posts: 6  Location: Boise Thanks: 1 times
I just downloaded the demo. I have been using ManyCam. I have numerous iphones that I would like to use as cameras. In the demo I have 4 inputs and can add 4 iphone inputs via VMix Call. It works really well so far. I would like to purchase the HD version for $350.00 but it says that VMix Calls are limited to 1. I am wondering if I am misreading this. I only ask because on the demo there are only 4 inputs and they can all connect to iphones.
You are not wrong. The functionality increases with the edition. The Trial version (free for 60 days) is for the Pro edition. So all functionality is available. Check out the comparison chart here: https://www.vmix.com/purchase/#comparisontable
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ Markarkark The Trial allows for up to 1000 Inputs (and 8 vMix Calls). Perhaps you have mixed up the 4 Overlay buttons as "Input" buttons, they are actually for the dsk (Down Stream Key) for lower third graphic overlays and PiP windows as explained in this video: Ice
Thank you I really appreciate it. This is a great program.
vMix Call
