jasminlord
#1 Posted : Wednesday, April 22, 2020 11:48:17 PM(UTC)
jasminlord
Hi
This is my problem:
I recording some show and i use
Bus A & B = Reporter (2 persons in vmix call)
Bus B = Production (2 persons in vmix call)
Everybody hearing B son the reporter can ear the cue.
So i send A to masters for the record.
But i use my microphone to talk to production and reporter on Bus B. I ear myself in my microphone. This anyway i case mute my microphone in my headphone.
Important: I use the option mute microphone in headphone, but when i talk in bus, it doesn't work.
Please help me to correct my setup, to mute my headphone.
dmwkr
#2 Posted : Thursday, April 23, 2020 12:44:19 AM(UTC)
dmwkr
One possibility: If you have set Bus A and B to a specific device In Settings / Audio Outputs you should set them to "Enabled".
If that doesn't help: What are your settings in Audio Outputs for Master and Headphones?
jasminlord
#3 Posted : Thursday, April 23, 2020 2:34:42 AM(UTC)
jasminlord
First thank for your help.
You have to know that i have 2 ouput in my soundcard
Back output = Speaker
Front output = Headset
So in my Audio setup in vmix i try those 2 setup and both doesn't work.
Setup 1. (No sound of B in my Headset)
Master = Backout output
Headphone = Front output
Bus A= Enabled
Bus B= Enabled
Setup2. (ear myself back in headset)
Headphone = Audio playback Device
Bus A= Enabled
Bus B=Front output
Please save me
dmwkr
#4 Posted : Thursday, April 23, 2020 3:36:21 AM(UTC)
dmwkr
I've been looking for a good setup for myself, and it is similar to your Setup 1.
Edit: Sorry, I think I had it wrong. I have also bus C enabled, route every input I want to hear there (so everything but the mic) and solo bus C (click the S on bus C in the Audio Mixer), and Setup 1 should work. Then, bus C is what you hear through your headphones, minus your input.
There are probably other ways to do it. You have to keep trying to find what is the best workflow for you.
thanks 1 user thanked dmwkr for this useful post.
jasminlord on 4/23/2020(UTC)
jasminlord
#5 Posted : Thursday, April 23, 2020 4:59:02 AM(UTC)
jasminlord
Never think of that solution... I try it and it's working. Maybe not the perfect way. But for now it's working.
Thank you very much :)
